Ring Once when avtive on CCM 4.2(1)sr1a not working
I think this is a bug. Has anyone else ran into it? I am tring to set it up where the phone only rings once when the phone is active but the phone just continues to ring. The flash only settings works fine. I have used this before on previous versions with no issurs. Am I missing something here.
Green
Re: Ring Once when avtive on CCM 4.2(1)sr1a not working
I reproduced the issue on my 4.2.1sr1.
DEs are working on this now.
Looks like a fix from a previous bug broke this feature.
Will keep you posted
Thanks very muck for the reply.
Does anyone know if there is already an offical bug for this or do I have to open a tac case to get that?
Green
The following DDTS to address this issue ...
has been submitted:
CSCsf07100 - Ring Setting (Phone Active)** does not work with 4.2(1) SR1
and SR1B
You can view this defect at the following link below ...
http://www.cisco.com/cgi-bin/Support/Bugtool/home.pl
The current workaround is to use CCM Version 4.2(1). I have no ETA of when the fix will be
incorporated.
You can track the resolution of the defect via the link provided.
Thank you
//G
Thanks again for your fast response.
Does any one know if this issues is fixed in Version in Version 4.23?
Hall of Fame Super Red
Hi Jeff,
This has been marked resolved;
CSCsf07100 Bug Details
Ring Setting (Phone Active)** does not work with 4.2(1) SR1 and SR1B
First Fixed-in Version 4.2(3.7)
Hope this helps!
Rob
142
