Community Member
Ring signal from PC speaker
Do anyone know if there is a way to get a ring signal in the PC speaker and in the headset at the same time?
Do I need to have a headset with USB connector and separate DSP to get this working?
Thanks in advanced,
Re: Ring signal from PC speaker
I don't know that you can do this using a USB headset at this point.
If you are using a legacy audio headset (plugged into existing sound card) then you can do this with a splitter.
Community Member
OK,
If I use a splitter, I connect external speakers and the headset to this and switch between them I guess?
98
