ring tone question.
can i assign diffrent ring tone based on caller group? just like if you use nokia handphone? or is there a way to configure a different ring tone to distinquish internal caller from pstn caller?
Re: ring tone question.
As of right now you can only have one ring per phone. Depending on the gateway you will get a different ring cadence for internal versus external calls. The current plans are in the next major version of callmanager to have distinctive ring per line.
Hope this helps,
-Mckee
thanks Mckee for your reply, i am using a mgcp gateway, how do i set diffrent ring cadence for internal and external calls?
106
