Ring tones for 7912G with CME
Anybody knows how to add ring tones to a 7912G IP Phone with Call Manager Express 3.3
It only have one ring installed by factory.
1 REPLY
Silver
Re: Ring tones for 7912G with CME
To change the ring type, perform the following steps:
Press the Menu button.
Press 3 on the keypad, or use the Navigation button to locate Settings and then press the Select soft key.
Use the Navigation button to scroll through the options. Use the Select soft key to select ring type.
Use the Navigation button to scroll through the ring types.
Use the Play soft key to play the ring sound sample.
When you find the ring you want, press the Select soft key.
Press the Ok soft key to save your ring selection, or press the Cancel soft key to exit to the previous menu without changing the setting.
Press the Exit soft key to return to the previous directory menu.
124
