Bronze
Ring Tones on 7910 Phone
Does the 7910/7912 phone have the capability to have multiple ring tone choices like the 7960/7940? On the set, when I select SETTINGS and scroll to ring types, the only choices given are Chirp1 and Chirp2. We are on CCM 3.2(2a). My 7910 phone load is P00403020204 (which is fairly old). I tried upgrading to the latest 7910 load (P00403020700) but couldn't get the 7910 to register with CCM so I went into CCM Device Defaults and reinserted the old load and I now have the 7910 registered and working but with only two choices on ring tones.
Bronze
Re: Ring Tones on 7910 Phone
No upgrade is going to help you in this case. 7910 simply does not support more than 2 ring tones
Bronze
Thanks for the reply. I found the answer this morning when I was building a custom ring tone (I had a request for a barking dog!!!). Cisco's document on Custom Ring Tones states: The following procedure only applies to creating custom rings for the Cisco IP Phone 7940 and 7960 models.
160
