Ringback Problems
When in a script I put a redirect there is no ringback when the call come from PSTN. I am connected to the PSTN with a PRI NET5 to a VG200 and the VG200 is using H323 to comunicate to CCM. Someone know how can i fix this problem? There is a special command in the gateway?
1 REPLY
Re: Ringback Problems
I have the same problem with IPCC express Callmanager and 3640 H323 gateway.
I have found som info related to this on
http://www.cisco.com/warp/customer/788/voip/ringback.html#pstn
The workaround seems to be uppgrading to 12.2 (2.4) or higher or use MGCP instead of H323
116
