Community Member
RisPort problems - argument type mismatch
Hi!
I'm trying to get a list of devices via RisPort. I copied example from http://www.cisco.com/univercd/cc/td/doc/product/voice/vpdd/cdd/5_0/ccmdev/ccmdvch2.htm chapter Real-Time Information (RisPort)
Selecting Cisco Unified CallManager Real-Time Information , but service returning following xml:
<?xml version="1.0" encoding="UTF-8"?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Server.userException</faultcode><faultstring>java.lang.IllegalArgumentException: argument type mismatch</faultstring><detail><ns1:hostname xmlns:ns1="http://xml.apache.org/axis/">CUCM6</ns1:hostname></detail></soapenv:Fault></soapenv:Body></soapenv:Envelope>
And my question is: How can I recognize, which argument? There are no any notes or details :-(
Many thanks for your ideas!!
ps. or is it posible to get that list any other way? (CUM6)
Community Member
Re: RisPort problems - argument type mismatch
check your gmail~i sent my code to your email!
here is the xml String:
String strSoapMsg=""+
"http://schemas.xmlsoap.org/soap/envelope/\" "+
"xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" "+
"xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\">"+
"http://schemas.xmlsoap.org/soap/encoding/\">"+
"http://schemas.xmlsoap.org/soap/encoding/\" "+
"xsi:type=\"ns1:CmSelectionCriteria\" xmlns:soapenc=\"http://schemas.xmlsoap.org/soap/encoding/\" "+
"xmlns:ns1=\"tns:CmSelectionCriteria\">"+
"2000"+
"Name"+
Community Member
oh, many thanks!!
seems like that now it connects to right service ..or another one, now it responses with "No target service to authorize for!" message :-(
where can be problem? Im sending to /realtimeservice/services/RisPort# and SOAP Action is http://schemas.cisco.com/ast/soap/action/#RisPort#SelectCmDevices
Community Member
Can you please share me the code mailed to you by blueant06 for this issue. Thanks in advance
Community Member
Hi!
Im really not sure, that i can share piece of somebody's else code, try to write him an email, sorry.
Community Member
Hi!
Would you mind posting the header you are sending? Are you using HTTP or HTTPS? thanks!
cheers,
alej
Community Member
ok, ill try to :-)
so, im sending to following address:
String url="https://"+getCmAddress()+":8443/realtimeservice/services/RisPort#";
and if youre sending to RIS, you need to specify more property: addRequestProperty("SOAPAction", "http://schemas.cisco.com/ast/soap/action/#RisPort#SelectCmDevices");
more headers: content-text/xml, POST method, Authorization Basic+BASE64encoded(user:pass)
...hope it helped, if no, ask ;-)
Community Member
cool, thanks!
and then you open a socket to the CCM on port 8443 and send the request? Are you developing in java? Do you add certificate data to the request?
cheers,
alej
Community Member
Can you please send me your code to my email gharikir@gmail.com
Community Member
Code on it's way!
Community Member
Hi guys,
I am a Cisco IP Phone application developer also. I have some problem in retrieving phone info with SNMP, just tring to find another way to follow. Would you mind to mail me your code as a reference? Thank you very much.
email: christmasoldman@gmail.com
335
