Community Member
Roll your own phone loads for CCM 5.0?
The software download page for phone loads has packages for the 7935/7936 phones that claim to be supported on CCM 5.0
Unfortunately the zip files only contain the .bin file and no .cop file
Since the .cop is just a renamed .tgz file, would it be reasonable to create our own packages? It looks simple enough, just modify loads3002.txt and include the appropriate os793X.txt file.
1 REPLY
Silver
Re: Roll your own phone loads for CCM 5.0?
The .cop files are like the .exe files in Windows. Therefore you shouldn't need the .cop file in this case. You should just be able to copy the .bin file to the server in the tftp folder and make the change under the device defaults and restart the tftp service.
110
