Route Pattern Limitation
adam.farrell
In earlier versions of CallManager there was a limitation of the number of route patterns that you could have. I know that this has been changed. Does any one know what the upper limits is now ?
Adam
wong34539
Level 6
Level 6
I don't see any such limitation existing now.
On CCM 3.1, if you use the @ in your route patterns, you can get about 300 in before it causes serious problems. After 300, if you add or update any route pattern the CPU will hit %100 for about 1 minute and sometimes CCM service will quit. You can insert a longer database initialization time in the service parameters and get about 1000 route patterns in, but each add will take down the service and you will have to do on off-hours. If you don't use the @ in your route pattern, it doesn't seem to cause problems although CPU will still spike for a few seconds when updating route patterns. Have not tried 3.2 with 1000 route patterns yet.
