Route pattern processing delay for 9.@
I am trying to configure route pattern 9.@ in CCM 3.3 to route call to IOS gateway.
It seems that the processing take long time than if you have some other pattern, for example 9XXXXXX.
Is there any workaround for this problem ?
1 ACCEPTED SOLUTION
Re: Route pattern processing delay for 9.@
You can assocaite a Route-Filter with your Route-Pattern and then it will know how many digits to look for.
You could have the user hit # after they dial the number.
You could shorten the Interdigit time out so that it only waits for 5sec instead of the default 10sec under neath the CCM global parameters.
1 REPLY
103
