Router/VoIP gateway modules versus a AS5300/Voice Gateway unit
Why would you use a 2600 or 3600 series router/VoIP gateway versus a AS5300/Voice gateway? What is the difference? Do I need a AS5300/Voice Gateway if I already have a router with a VoIP module? Is it a scalability issue?
Re: Router/VoIP gateway modules versus a AS5300/Voice Gateway un
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources online at http://www.cisco.com/go/solutions. You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit http://www.cisco.com/warp/public/687/Directory.shtml
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
If you're going to need more than 2*T1/E1, the 5300 is more cost-effective per port. If you need that router to do things that require more CPU (filtering, routing processes) or more packet-handling ability (multiple interfaces or small codec samples) then a 3600 may be more appropriate, especially if there is an existing deployment of modular routers.
141
