You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Routing incoming calls
I have 2 pots lines coming into a FXO card. I have plar these lines to an extension. Is there any way to have these lines ring on muliple phones at the same time??
  • Other Collaboration Voice and Video Subjects
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Routing incoming calls
You can confire the dialed number as hunt pilot pointing to hunt list which points to line group listing all the phones you want to ring, you can do a broadcast ring where all phones ring at the same time, or longest idle, etc.
Refer to CCM Admin guide for more details.
HTH, please rate all helpful posts!
Chris
What do you use as a call routing? CallManager, Callmanager Express, just FXS cards?
With CCM and CME you can create hunt groups, or shared line appearance.
Chris
CCM 4.0 Could I assign an extension to the incoming posts and use hunt groups??
Chris
118
