Routing outbound calls
Hello everybody.
I have a 2801 router (Call Manager Express) with a 4FXO card, and each port is connected to a PSTN line (4 to 4). I have four ip phones (7902).
I need each ip phone make calls always through the same PSTN line. I only know how to choice the fxo port using the destination pattern, but I don?t know how to select the fxo port based on the phone wich make the call.
I?m a newbee with this themes, so any help will be welcome.
Thank you for your attention.
Re: Routing outbound calls
hi,
you can configure dial-peer for :
calling-number and your IP Phone extension number.
This will allow only that phone to use that FXO port.
-r
v
Thank you for the response!
There is a problem. When I configure a new dial-peer the calling-number option is not recognized by the IOS.
I use: dial-peer voice 1 pots
And now I use ? and the calling-number is not part of the DIALPEER configuration commands (beginning by letter c I only have call-block, capacity and carrier-id).
The version of IOS is 12.3(11)T10, Release software (fc4).
Thank you!
Well, this link show how to get we I want:
http://www.cisco.com/warp/public/788/products/specific_fxs_call.html
But I have a problem. I can?t dial any number that doesn?t match a destination-pattern. In theory after the translation rule, the called number should match de destination-pattern.. but it doesn't...
Any sugestion?
Thank you!
Silver
You can use the trunk command to dedicate the FXO per user. Here is a sample config.
ephone-dn 1
number 1000
trunk 80
ephone-dn 2
number 1001
trunk 81
dial-peer voice 10 pots
destination-pattern 80
Port 1/0/0
destination-pattern 81
Port 1/0/1
Based on the above config, when the user at 1000 goes off hook and dials 80, he will grab the FXO port 1/0/0. This way each user can have a separate trunk port.
Anup
Hey! Thanks Anup.
I have already think in that solution. The problem is that each user must dial some prefix before dial the number, and I dont want this.
I have used other voip/pots gateways and was very easy to create a rule that assign incoming voip calls to fxo ports based on the calling number, but I dont find and "easy way" to this with the 2801 router, and I think this should be a trivial task, but it isnt.
Thank you again!:)
144
