12-14-2005 09:56 AM - edited 03-15-2019 03:57 AM
Hello guys,
My task is to configure the RSVP protocol. I need to see the Path messages Resv messages and some others in the network. I am configuring RSVP the first time and faced to some problems..
Could anybody suggest any easy way how to configure it between some devices to see this packets?? Any suggestion or..
Topology
lo0-Routerfa0/0 - fa0/0.94 Router -lo0
Now I am trying to simulate the RSVP Path and Resv messages using
ip rsvp reservation and ip rsvp send commands:
While debugging I see some initiation but show ip rsvp counters command doesn't display any Resv and Path messages transmited. I tried to configure this the same way but using ip rsvp sender-host and ip rsvp reservation-host but also unsuccessfully.
ITP
ip route 0.0.0.0 0.0.0.0 212.109.48.169
no ip http server
ip rsvp sender 212.109.47.62 212.109.47.173 1 0 0 212.109.48.171 FastEthernet0
/0 5 1
ip rsvp reservation 212.109.47.62 212.109.47.173 1 0 0 212.109.47.173 FastEthe
rnet0/0 FF RATE 5 1
ip rsvp signalling hello statistics
interface Loopback0
ip address 212.109.47.173 255.255.255.255
interface FastEthernet0/0
ip address 212.109.48.171 255.255.255.248
MGC:
ip rsvp sender 212.109.47.173 212.109.47.62 1 0 0 212.109.48.173 FastEthernet0
/0.94 5 1
ip rsvp reservation 212.109.47.173 212.109.47.62 1 0 0 212.109.48.62 FastEthe
rnet0/0.94 FF RATE 5 1
interface Loopback0
ip address 212.109.47.62 255.255.255.255
interface FastEthernet0/0.94
ip address 212.109.48.173 255.255.255.248
What do I make wrong??
Thank to everybody in advance.
12-15-2005 09:17 AM
afaik the commands allows a router to send RSVP instead of a host attached, like an "RSVP proxy".
So you would need two hosts generating traffic.
What you probably are looking for is "ip rsvp sender-host" and "ip rsvp reservation-host". Here the router generates PATH and RESV messages.
Have a look at
Hope this helps
Martin
12-15-2005 02:13 PM
Try adding the "ip rsvp bandwidth" command on all interfaces in the network that will make up the RSVP path. In this case Ethernet and WAN interfaces.
