RTP header compression and policy maps
rbradfield
Level 2
Level 2
There has always been a problem, getting the bandwidth correct, when using
a policy map, we have to allow about 26kbps per G729 call, within the policy-map, but then when using the frame-relay ip rtp header-compression, it gets compressed to 11.6Kbps, for example we want 5 concurrent calls on a 128kbps link, in the Policy-map that would be 130kbps which is over the 128k, and doesn't allow any bandwidth for the signalling.so we have had to say the bandwidth was more than 128k for things to work.
I see with 122-13T there is now class based RTP& TCP header compression
which overcomes this problem... Has anybody used this yet? If I have one router running an earlier release of IOS with the frame-relay IP rtp Header compression, will that work with a router running the new class based header compression?
any comments most welcome, and a Happy new year to everybody.
rbradfield
Level 2
Level 2
Answeriing my own question
managed to do some testing this is the policy map applied to a frame relay interface
policy-map 256kCIR
class VOIP-RTP
priority 280
compress header ip rtp
class VoIP-Control
bandwidth 10
class class-default
police cir 240000
conform-action transmit
exceed-action drop
here is the sh frame pvc 200 showing the policy map traffic, one voice call no other traffic
Class-map: VOIP-RTP (match-any)
5838 packets, 373632 bytes
30 second offered rate 25000 bps, drop rate 0 bps
Match: ip precedence 5
30 second rate 25000 bps
Match: ip dscp ef
0 packets, 0 bytes
30 second rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 40
Bandwidth 280 (kbps) Burst 7000 (Bytes)
(pkts matched/bytes matched) 5839/373696
(total drops/bytes drops) 0/0
compress:
header ip rtp
UDP/RTP compression:
Sent: 4850 total, 4849 compressed,
184259 bytes saved, 106741 bytes sent
2.72 efficiency improvement factor
99% hit ratio, five minute miss rate 0 misses/sec, 0 max
rate 8000 bps
You can see the the 30sec offered rate still says 25000 bps, and after compression the max rate was 8000bps
when i did ahow interface you see it is about 12000bps
30 second input rate 11000 bits/sec, 52 packets/sec
30 second output rate 12000 bits/sec, 52 packets/sec
So the problem is still not fixed, I still have to allow 25k for each call in the
policy- map even though it is really only taking 12k, that means when the policy-map is created I cannot put the true CIR, i have to fudge it to make it work.
anybody else know of anything different.
