Community Member
RTP Header compression
All the training material says the level of compression depends on whether the checksum is send or not. How is this decided, is it configurable
Community Member
Re: RTP Header compression
UDP checksums are enabled under VoIP dial-peers using the following command:
dial-peer voice xxx voip
ip udp checksum
Hall of Fame Super Gold
Will be interesting to see if the OP still needs an answer after almost 4 years.
314
