Running BAT to create ADP on users associated with two devices
Problem Details: I have a couple question about behavior of the Bulk Administration Tool that allows you to automatically generate Device Profiles.
1) If a user is associated to a 7941 and a IP Communicator and you run the tool and select to use the personal profile as the logout profile will it set the user as the logout profile for both of the associated devices?
2) Does it port Speed Dials as well as lines?
1 REPLY
Silver
Re: Running BAT to create ADP on users associated with two devic
When you select the logout profile for the user, it will be applied to all the associated devices for that particular user.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008087416c.shtml
125
