03-25-2002 05:11 AM - edited 03-12-2019 02:56 PM
Hi ,
Is it possible to work with an external SQL Server ???
03-25-2002 05:24 AM
i think it should work, since the ccm uses standard odbc-connections. the other question is : does cisco support it ???
03-25-2002 06:45 AM
And if you have to ask - the answer is quite likley no :-)
03-25-2002 07:07 AM
Not sure if it would work or not but I know this would not be a Cisco supported configuration.
Thank you,
-Mckee
