Running Call-Manager on a centralized SQL Server
Hi ,
Is it possible to work with an external SQL Server ???
Re: Running Call-Manager on a centralized SQL Server
i think it should work, since the ccm uses standard odbc-connections. the other question is : does cisco support it ???
And if you have to ask - the answer is quite likley no :-)
Not sure if it would work or not but I know this would not be a Cisco supported configuration.
Thank you,
-Mckee
92
