Running Hardware Detection
At the splashscreen if I press esc and watch the files get copied it freezes at this screen:
Running Hardware Detection Screen...
System ID:CPQ0727
_
The cursor is blinking but the CD is no longer running. The server is a Compaq DL380 G3 with over 1 gig of memory. It is right out of the box with all the factory defaults. Why is the setup bombing at this point?
Bronze
Re: Running Hardware Detection
What version does the OS cd's you are using have printed on them? Is there a DVD in the set (disc 3)?
Version 2000.2.3 and there is no DVD in the set.
Bronze
This is likely the problem, you need 2000-2-4.
You can get it by going to www.cisco.com/upgrade, and put in your smartnet contract number for the CCM SW.
91
