03-04-2008 02:35 AM - edited 03-13-2019 05:01 PM
I want to make a running text on the ip phone screen, i can't make a delay while moving the letters, setTimeout() is not working, please tell me what alternative function to use.
03-04-2008 03:58 AM
You can ONLY send static text / pictures / menu's to Cisco IP phones. This means you will not be able to modify text without een screen refresh.
You could send a CiscoIPPhoneText XML object containing some text, wait for a second and then send it again with other text.
Good luck!
03-05-2008 01:40 AM
Thanks alot for your help.
03-12-2008 04:15 AM
Dear Sir;
I used the screen refresh every 1 second, but i need the screen to be refreshed every 500 millisecond , can u help me please in this point.
