09-16-2003 06:03 AM - edited 03-13-2019 01:37 AM
I've installed all approved service packs and MS hotfixes as per Cisco document 40_sysrq.htm and Unity is running fine. My customer is concerned about not having WIN-SP4 and or additional MS hotfixes installed on the Unity server. The build is in an AD WIN2003 enviroment and off box Exchange2003 standard. Can you please advise all or additional supported MS patches that can be applied to the Unity server?
Thank you,
Solved! Go to Solution.
09-16-2003 08:58 AM
Our policy is explained here:
Basically we support all of the hot fixes as soon as they are released and service packs after they are qualified. Windows 2000 SP4 is now qualified.
Keith
09-16-2003 08:58 AM
Keith
09-16-2003 09:57 AM
Great!
Thank you!
