Save Unity with DiRT, uninstall & restore it
we plan to do the following:
- save greetings etc with DiRT
- uninstall Unity
- change NT-accounts for Unity
- install Unity off box (without Exchange)
- install Unity with German OS, MSDE (not SQL), IE ...
- restore DB with DiRT
is that possible?
Will DiRT restore the Exchange 5.5 properties for Unity, after uninstall?
Is it a problem to change NT-Accounts (names)?
Nice weekend,
Axel
1 ACCEPTED SOLUTION
Re: Save Unity with DiRT, uninstall & restore it
yes, this will work fine - check out the help files and training videos for DiRT on it's home page here:
http://www.ciscounitytools.com/App_DisasterRecoveryTools.htm
I cover issues just like this. DiRT is designed to restore Unity specific data without caring or knowing what the original back end/configuration was or what the new backend/configuration is - so you can go from Ex55 on box to E2K off box or the like without it caring. It pulls all such information off the new install before doing the restore and then makes sure that's all preserved properly.
This is why you must restore DiRt onto a fully functioning, clean install of the same version of DiRT that you backed up - that way it can avoid having to cart all the message store/directory store configuration information around and converting it.
1 REPLY
92
