Script CCM SQL database
There are hundreds non-900 adult calles or some south America country calles, we need a way to bulk add blocked route-pattern or translation-pattern.
Does anyone have the idea how to script it to bulkly edit/add/modify CCM configuration SQL database.
The BAT tool is too limited. Unity can provide such capability, CCM should have a way.
If I am familar sufficient with the schema and architecture of the CCM SQL database, may can script it.
I appreciate anyone can provide helpful input or point contact.
Thanks a lot.
Joe
CCIE, CIPT, UCSE
MCSE, MCDBA
Re: Script CCM SQL database
got just the thing.
check out www.nzice.com/deployer.htm, www.nzice.com/swdev.htm
allows you to create call manager configs in excel files, then uses AXL to push the configs to a target call manager.
a little complex to set up, but i could help you with that part if you are interested.
regards,
callum
Great, thanks a lot. I will try it by myself first, then I can ask the question right to the point.
Have a nice day!
It is big snow storm out of Michigan :(
294
