Community Member
SDK LocalizedDirectory Issues
I had made some basic changes to the localizedDirectory.asp file of IP Services SDK to make it work my win2k3 AD database, After modification the script is able to pull the telephone number from AD if i try a search using the "FirstName" or "LastName" as search criteria.
But it does not pull any data if i try a search using the telephone number as critera, i checked doing the same directly on the AD and it works there. Is there any way to debug this on ip phone ? Any comments or suggestions for what could be going wrong ?
mshekhawat
107
