Separate DHCP pools for Voice and Data VLAN's
We are configuring a Cat4500 to support voice and data on the same switch port. The 4500 must provide separate dhcp pools for the voice and data vlans:
ip dhcp pool Data
network 192.168.101.0 255.255.255.0
default-router 192.168.101.1
ip dhcp pool Nortel-IP-Phones
network 192.168.120.0 255.255.255.0
default-router 192.168.120.1
int vlan101
ip address 192.168.101.0 255.255.255.0
int vlan120
ip address 192.168.120.0 255.255.255.0
Would the following port configuration allow the IP phones, and the workstations attached to them, to pick up an IP address from the correct DHCP pool?
interface fas4/1
switchport mode trunk
switchport nonegotiate
switchport voice vlan 120
spanning-tree portfast
spanning-tree bpduguard enable
Thanks in advance
Hall of Fame Super Silver
Re: Separate DHCP pools for Voice and Data VLAN's
You actaully do not need to setup a trunk on the switchport, all you need is the following:
interface fas4/1
switchport mode access
switchport voice vlan 101
Chris
Copy and past error, I ment:
interface fas4/1
switchport access vlan 101
375
