Separate Directories In CallManager
We're planning centralized call processing for 5 sites and I want individual Corporate Directories for each site. How is this done?
Re: Separate Directories In CallManager
Very carefully. Actually it's a fairly simple XML app that filters the LDAP on the DC Directory. The biggest trick was finding a 3rd-party ActiveX LDAP controls that I could call from an ASP page. I was able to do it, and I haven't coded squat since Pascal and C++ in College.
Ok. Can you be more specific as to what I need to do to make it all work?
The problem is, Cisco's directory lookup uses a closed tool to do the actual search, so my first attempts to modify Cisco's lookup failed. What I found was an ActiveX Ldap tool from www.ldapservices.com. With that I can run an LDAP search, with my own criteria, directly from an ASP script. I just format the output of the ASP to conform to Cisco's Phone Directory XML, and I'm golden.
Blue
You can attempt to do it on your own or e-mail me at adignan@berbee.com and we can provide you with what you need to get it to work.
103
