Service for dialing -- Pls Help
I need to write a service that will give a base menu to the phone of which one is international call. I would like to then display a list of countries and then let the user select the country to where he/she wants to call and then be prompted for the number, and press Dial to connect the call.
I am very new to developing services and I have made the menu but as soon as I press "2" for intl. dialing and reference the URL the phone doesnt do anything??
Can someone maybe help me with regard to this??
Silver
Re: Service for dialing -- Pls Help
It might be a problem with the URL associated with that menuitem. Is it a valid url? Can the phone reach it? Do you get a host not found error, or does it just take no action at all? Do the other menu choices work correctly?
I would suggest starting by checking the output of that page, perhaps by calling it in a browser, and examine the urls associated with each menu item, if you haven't already.
Just to check, are you using the CiscoIPPhoneMenu xml object and not the CiscoIPPhoneText object? Just checking!
I got it fixed thanx, It wasnt seeing the url.
But now I have another Question for you. I have a CiscoIPPhoneInput Object in the next page that needs to add the selected digits and dial the nr.
My asp look like....
Response.Write("\r\n");
Response.Write(" InterNet Protocol Calling \r\n");
Response.Write(" Please enter the telephone number \r\n");
Response.Write("Dial:"+code+telnr+"\r\n");
Response.Write(""+country+": +"+code+"\r\n");
Response.Write("telnr\r\n");
Response.Write("N\r\n");
return;
Does the QueryStringParam look ok ?? or what should i put in there to be able to dail country+telnr ??
Thanx
247
