session concept in IPCC call flow programming
Customer has this requirement:
Caller calls in and enter his employee ID, if IPCCdetects this is an abandoned call(for example this caller called 30 minutes ago and entered the employee ID , but he hung up) and all the agents are busy, system will treat this as a higher prority caller and transfer to agent whenver agent is free. If IPCC detects its a new call then just treat it a regular call. I think this is done by session. BUt I don't know how to do that. Can anyone give me a simple example to make me clear? Thanks a lot.
  • Other Collaboration Voice and Video Subjects
Anonymous
N/A
Re: session concept in IPCC call flow programming
Here is a link for Scripting on Session concept in IPCC.
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_technical_reference_
But this link doesn't work.
Bronze
You will have to create a Session Map in the script, mapping the Employee Id.
The CRS system assigns the same session if the call comes within the half hour.
Now when a new call comes in, get the employee id, then get session info. compare the mapped value (if present ) with the new id entered, if they match, set the priority if they dont match, set the session info and proceed with the call normally.
155
