Set up IPT phone (7912, 7940) with pw for IDD call
Hi,can some one share with me how to set call manager V4.0 with pin and CSS to restrict public IPT extension to do outside local and IDD call.
Au Ray
Singapore
1 ACCEPTED SOLUTION
Re: Set up IPT phone (7912, 7940) with pw for IDD call
After taking a look at the administration guides, I noticed that FACs are not mentioned in the 4.0 guide. They are available in 3.3 and later versions and 4.1 and later versions. I can't find documentation to support this, but it seems they were not available in 4.0 for some reason. Looks like you would need to upgrade to at least 4.1(x) to take advantage of FACs. Sorry for the bad news.
Brandon
You can use Forced Authorization Codes. See the following link.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a00807d11d4.shtml
Hope this helps. If so, please rate the post.
Brandon
Brandon,
Tks for your quick response. However, I can not this force authorication feature in Call manager V4.0. admin menu. The document advised is valid for 3.3 or later. Does my operating copy 4.02 (2a) sr2c admin version 4.0(0.333) miss something. How to activate the force authorization feature? need your guidance.
Ray Au
Singapore
Brandon
Hall of Fame Super Red
Hi Au Ray and Brandon,
Here is a Field Notice that confirms this :(
Field Notice: Cisco CallManager 4.0(1) Upgrade Issues and Considerations
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_field_notice09186a0080229a8b.shtml
Hope this helps! Sorry man,
Rob
Rob & Rbandon. I extraced the following from in Rob's suggested link. The
Force authorization code is only available in version 4.0 I have no solution in v4.0. I have informed my user group to implement the feature in newer release.
**Forced Authorization Codes and Client Matter Codes
Forced Authorization Codes and Client Matter Codes will not be addressed in Cisco CallManager 4.0, but will be introduced in Cisco CallManager 4.1 to be released in late 2004.**
Thks for your help
Au Ray
Singapore
142
