Set up Voice lab
Hello ,
I am trying to set up voice lab . I have the server already configured and conneted to my router cisco 2800.
It's connected to  hwic 4esw card . The router connected to a switch: catalyset 2960 . Server IP 31.168.170.115.
I need to access the server via web and ssh from a station connected to the switch .
Router configuration
Current configuration : 1178 bytes
version 12.4
hostname Lab_Router
boot-start-marker
boot-end-marker
logging message-counter syslog
enable password cisco
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
archive
 log config
  hidekeys
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed 100
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10
 ip address 172.50.1.254 255.255.255.0
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
 ip address 192.168.192.254 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
ccm-manager fax protocol cisco
mgcp fax t38 ecm
line con 0
line aux 0
line vty 0 4
 password cisco
 logging synchronous
 login
 transport input telnet
scheduler allocate 20000 1000
end
Lab_Router#
1 REPLY
You'll need to do a port
You'll need to do a port forward from your internet facing device to CUCM for web and SSH access. It doesn't look like this 2800 router is internet facing...what device are you using and I might be able to help you with that config. It might be a better solution to have a station you RDP to for everything.
95
