12-27-2011 04:03 PM - edited 03-13-2019 07:39 PM
Hi, my client is send to SIP G711, G729 Voip calls through the internet, how can I use cisco router 2811 for terminate the calls? I do not have a PSTN. Thanks
12-28-2011 07:32 AM
There are some docs on CCO about setting up a SIP trunk on CME, have you already gone thru those???
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
12-28-2011 11:49 AM
I have not seen the Docs you mention, would you please give me the address where I can find the doc on CCO.
Thank you
James
12-28-2011 12:38 PM
You just need to take one minute to search CCO for "SIP trunk configuration" to get the docs
java
