setting CUE clock without NTP
mmahannah
How can I set the CUE clock from the CLI? Only option I see is NTP server which I don't have yet. It does not sync with the CME router clock.
agopala
the clock takes the time from the router in which it is installed. So, if you install a new CUE, and do "show clock" it will show you the same time as you have on the router. There is no need to put in a command, unless you want it to follow an NTP server. that is the reason you do not see a command for that
