Community Member
Setting Router LLQ Priority for Picturetel H.323
I need to know what ports I need to assign to an llq QOS priority group on my 3640 routers for H.323 Video Conferencing with 2 Picturetel 970 Video Conferencing units for Voice and Video Priority, also what would you recomend for the amount of bandwidth allocated for voice and video on a point to point T1.
Community Member
Re: Setting Router LLQ Priority for Picturetel H.323
Hi , the TCP and UDP ports used by PT 900 Series
is the follow:
TCP traffic (port range: 1700 to 1750)
Call signalling for call establishment: 1720
UDP traffic
UDP audio traffics use port range 17000 to 17050
UDP video traffics use port range 17100 to 17150
Other UDP traffics, such as RAS, use port range: 1700 to 1750
IP Precedence TOS (type of service) byte usage:
UDP audio traffic use TOS byte of 0xA0 (IP Precedence 5)
UDP video traffic use TOS byte of 0 (IP Precedence 0)
I have a very similar equipment, but i don´t know much about llq apply to frame-relay. You can to help me, Because I need to configurate llq for Frame relay .Please
Community Member
Thank you for your information. In response to your Frame Relay Question I am putting a sample config below. I am using this setup to prioritize voip over a frame relay link. You will have to adjust your port #'s in the access list for video and also will probably have to change the bandwidth settings and CIR settings for your particular frame CIR. I had the TAC help me with this configuration and as you can see it is a little more complex than on a Point to Point Link. Good Luck.
class-map match-all voiceframe
description voice traffic for Frame Relay
match access-group 105
class-map match-all dataframe
description data for frame relay
match access-group 106
policy-map llqframe
class voiceframe
priority 144
class dataframe
bandwidth 144
class class-default
fair-queue
interface Serial0
bandwidth 384
no ip address
encapsulation frame-relay
no fair-queue
frame-relay traffic-shaping
frame-relay lmi-type ansi
frame-relay ip rtp header-compression
interface Serial0.30 point-to-point
bandwidth 384
ip address xxx.xxx.xxx.xxx
frame-relay interface-dlci 30
class llqvoiceframe
map-class frame-relay llqvoiceframe
frame-relay cir 384000
frame-relay bc 3840
frame-relay be 0
frame-relay mincir 384000
no frame-relay adaptive-shaping
service-policy output llqframe
access-list 105 permit udp any any range 16384 32767
access-list 106 permit ip any any
Community Member
Video conferencing systems use the rtp port range for media communications. This range is 1024 to 32757. Some VC systems allow you to configure a specific rtp port range for use. If so, you can narrow the port range necessary for your purposes. Remember that video calls actually use 2 rtp ports as voice and video are separate streams and both should be funnelled to the same LLQ.
As for b/w, a good formula to calculate necessary b/w - ISDN speed (e.g., 384k) + 10% IP overhead + 5% if encapuslating IP in frame relay or ATM or something.
168
