Setting up COR on CCME
Gurus,
I'm trying to get COR configured on my CCME. It is extremely basic - I do not want to block anything incomming (i.e., TO the phone, so I guess technincally that's OUTGOING??), and need to set up blocking for calls dialed OUT to the following: international, long distance, 1900. About half the phones will be wide open, with no restrictions, and the other half will be blocked to local only, toll-free, and 911. Our system requires the 9 to be entered before the number, and we get our dial tone from a PRI T1.
I understand, basically, about setting up the "dial-peer cor custom" list and then the individual named lists, but could someone give me some guidance on how to set up the actual dial-peer that specifies the destination-pattern? My Cisco CCME book gives one example:
Dial-peer voice 1 voip
Destination-pattern 1800...
Session Target:ipv4:10.10.10.2
dtmf-relay h245-alphanumeric
and I've found others online:
dial-peer voice 7 pots
corlist outgoing LOCAL
destination-pattern 9[2-9]......
port 2/0:23
forward-digits 7
These two look so totally different, I am not sure what is appropriate.
Thanks for any advice you can give.
-Michael
1 REPLY
Silver
Re: Setting up COR on CCME
They look different because one is a voip dial-peer and the other one is a pots dial-peer. The basic difference between these two being that voip dial-peer is used if you want to send calls to a voip endpoint and pots dial-peer is used to send calls to the PSTN via FXO or PRI lines.
The basic components of a dial-peer are
1. match the dailed number:
destination-pattern
2. where to send the call:
dial-peer voice 1 pots
port 2/0:23
dial-peer voice 2 voip
session target
3. how many digits to forward to the remote end
forward-digits 7
This is needed in pots dial-peer because by default it would forward only the digits that are not explicitly matched. That means, in your example if the user dials 92125555, the PRI service provider will receive only 125555. 9 and 2 will be dropped because of the explicit match.
On the other hand, VOIP dial-peer will forward all digits. So this command does no apply there.
What you would need is something like this
port 2/0:23
forward-digits 7
corlist outgoing LONG-DISTANCE
destination-pattern 91[2-9]..[2-9]......
port 2/0:23
forward-digits 11
corlist outgoing INTERNATIONAL
destination-pattern 9011T
port 2/0:23
prefix 011
T is a wild card to match any digits and it also waits for the interdigit timeout.
Because of the explicit match discard digit behaviour , you would need to use the prefix command to send 011 via the PRI.
There are a lot more to dial-peers. These links would be helpful.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010ae1c.shtml
Anup
119
