setup voice PRI T1 using VWIC2-2MFT-T1/E1
I am trying to setup PRI T1 using VWIC2-2MFT-T1/E1. I wasn't able to bring up this T1 with local provider. This is what I have on my router.
isdn switch-type primary-ni
controller t1 0/0/0
framing esf
lincode b8zs
pri-group timeslots 1-24
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
Anything do I have to worry about to bring this T1?
Thanks.
Peter
Re: setup voice PRI T1 using VWIC2-2MFT-T1/E1
Hi Peter,
Since this is a voice circuit, I'd try removing the "encapsulation hdlc" on the Serial0/0/0:23 statement.
Also, you didn't mention what platform you're using this VWIC2 on. I have done a number of deployments on the 2821 ISR platform, which required additional configuation to bring up the VWIC with the provider. I use:
network-clock-participate wic 0
network-clock-select 1 t1 0/0/0
Hope that helps,
-JFO
i tried to remove the "encapsulation hdlc" from the same interface on a router that I have, and it takes the command with no errors. But when I do a show run, "encapsulation hdlc" is still on the interface. Am I correct in assuming that it is there by default, but does not normally show up in the config?
Peter,
Did my suggestion provide any traction for your issue?
-JFO
JFO and Peter,
I have seen that hdlc encap command in the new 12.4 IOS. Doesnt do any harm though. You cannot remove it.
Peter, what does a show isdn status give ya ?
146
