Community Member
Simple h323 with CCM question
I am attempting to set up the following:
I have a POTS line plugged into FXO port 0/1/3.
I want that POTS line to ring extension 89047 on CCM.
I know this is simple, but I must be missing something. Here is what I have on config:
dial-peer voice 33 pots
description Line_3
direct-inward dial
progress_ind setup enable 3
progress_ind alert enable 8
forward digits all
port 0/1/3
dial-peer voice 999992 voip
preference 1
destination-pattern 890..
session target ipv4:10.10.1.50 (CCM ADDRESS)
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
Silver
Re: Simple h323 with CCM question
you need: connection plar 89047 on the voice port.
HTH Pls rate!
Community Member
Sorry I did not include that in original. I do have the PLAR statement. I can do a debug on the dialpeer, and it is hitting the proper dialpeer and trying to dial 89047, but I get fast busy. 89047 is a Hunt Pilot in CCM.
Silver
Can you dial the hunt pilot internally? Does it work?
Community Member
Yes, from an FXS port regisered MGCP it is possible to dial the hunt pilot.
Silver
did you try connection plar opx?
Community Member
No luck with OPX statement. It will ring, but no answer when using OPX.
Thansk
Silver
Can you port more of the router config? Is the hunt pilot in a partition?
123
