Simple Question about E1
1- For 2811 Gateway(VoIP only): does VWIC-2MFT-E1 (2-port RJ-48 multiflex trunk VWIC—E1)means that i have the ability to have 2 E1 links? 60 Channels(30 for each ports) or do i need another Card to have 2 E1? so i just have to plug two RJ48 Cables on the E1 Cards and the Other End on the Multiplexers?
2-How can i configure the second E1 if already have one E1 working?
3-Two-port version supporting E1 balanced and unbalanced lines
What is the difference between balanced and unbalanced lines?
Re: Simple Question about E1
Any answer???
Bronze
Your configuratuion will depend if you are using ISDN PRI signalling or R2 signalling.
Silver
check this url:
Im using ISDN PRI.
what about question 1????
1 . you can put two e1s depending on how many DSPs you have.
2. you can simply configure the pri-group command under the second E1 controller.
Thanks hanky
1. we have PVDMII DSP SIMM with one DSP and PVDMII DSP SIMM with three DSPs. Is that ok? or should i better buy an one port E1 voice card
Please paste the output of "show voice dsp group all"
didnt find "show voice dsp group all" however i paste show dsp all:
Dspfarm Profile Configuration
Profile ID = 1, Service = TRANSCODING, Resource ID = 1
Profile Description : TRANSCODE
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 12
Number of Resource Available : 12
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Codec : gsmfr, Maximum Packetization Period : 20
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 5 4.3.26 UP N/A FREE xcode 1 - - -
0 6 4.3.26 UP N/A FREE xcode 1 - - -
0 7 4.3.26 UP N/A FREE xcode 1 - - -
Total number of DSPFARM DSP channel(s) 12
A sample output of sh voice dsp group all looks like below (this is from a 2821 i have with me here). Not sure what IOS you are using. Slot 0 is the onboard slot and I have a PVDm2-32 on board, which shows two DSPs each 16 channels. This would be sufficient for 1 E1.
PCPMG-CME#sh voice dsp group all
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 8.2.0
Max signal/voice channel: 16/16
Max credits: 240
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 240, reserved credits: 0
Signaling channels allocated: 16
Voice channels allocated: 0
Credits used: 0
dsp 2:
Max credits: 240
Signaling channels allocated: 7
Credits used: 0
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
0 DSP resource allocation failure
Also it looks like you have transcoding configured. Depending upon how many resources have allocated for that, the number of DSPs available to you to configure 60 channels for two E1s will be short.
I didnt get that command, any way back to question 2:
When i plug one end of the cable in the second port of E1 card and the other end in the multiplexer, what should i do next? go to config mode and type
pri-group timeslots 1-31 , is that all?
158
