SIP:FXS keep ringing when ATA186 Cancel call
I setup the following
C3640(FXS)---SIP Proxy----SIPHardPhones(C7960 and ATA186)
C3640 IOS 12.2.13T1(10.10.10.50)
C7960 SIP V4.3.0(10.10.10.31)
ATA186 v2.15(10.10.10.35)
SIP Proxy (10.10.10.66)
Problem encountered
When ATA186 call FXS, the phone ring with no pickup
When AT186 hangup, the FXS phone keep ringng.
I had tried with C7960
When C7960 call FXS, the phone ring with no pickup
When C7960 hangup, FXS stop ringing.
I capture the message for both events
On the ATA-FXS case, the C3640 send 481. See below
ATA-FXS case
Mar 13 06:46:17.377: Sent:
SIP/2.0 183 Session Progress(<-FXS ringing)
Via: SIP/2.0/UDP 10.10.10.66;branch=z9hG4bK1c14.a89041f1.0,SIP/2.0/UDP 10.10.10.
35:5060
From: <sip:1415@10.10.10.66;user=phone>;tag=131753000
To: <sip:92800@10.10.10.66;user=phone>;tag=9ED0964-1037
Date: Thu, 13 Mar 2003 06:46:17 gmt
Call-ID: 4283705521@10.10.10.35
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 154
v=0
o=CiscoSystemsSIP-GW-UserAgent 1743 5402 IN IP4 10.10.10.50
s=SIP Call
c=IN IP4 10.10.10.50
t=0 0
m=audio 16952 RTP/AVP 0
a=rtpmap:0 PCMU/8000
Mar 13 06:46:26.617: Received:
CANCEL sip:2800@10.10.10.50:5060;user=phone SIP/2.0(<--ATA hangup)
Max-Forwards: 10
Via: SIP/2.0/UDP 10.10.10.35:5060
CSeq: 1 CANCEL
User-Agent: Cisco ATA v2.15 ata18x (020927a)
Content-Length: 0
Mar 13 06:46:26.621: Sent:
SIP/2.0 481 Call Leg/Transaction Does Not Exist(<---FXS keeps ringing)
35:5060
CSeq: 1 CANCEL
Content-Length: 0
C7960-FXS case
Mar 13 06:42:18.949: Sent:
Via: SIP/2.0/UDP 10.10.10.66;branch=z9hG4bKfebc.4735db72.0,SIP/2.0/UDP 10.10.10.
30:5060
From: "67890" <sip:joecp2@10.10.10.66>;tag=000af4d543940046085f67ce-610ff26c
To: <sip:92800@10.10.10.66>;tag=9E96600-1914
Date: Thu, 13 Mar 2003 06:42:18 gmt
Call-ID: 000af4d5-439401fa-69199fef-62e03a1e@10.10.10.30
CSeq: 101 INVITE
Content-Length: 154
v=0
o=CiscoSystemsSIP-GW-UserAgent 1588 5019 IN IP4 10.10.10.50
s=SIP Call
t=0 0
m=audio 17250 RTP/AVP 0
Mar 13 06:42:26.469: Received:
CANCEL sip:2800@10.10.10.50:5060 SIP/2.0(<-C7960 hangup)
Max-Forwards: 10
Via: SIP/2.0/UDP 10.10.10.30:5060
CSeq: 101 CANCEL
User-Agent: CSCO/4
Content-Length: 0
Mar 13 06:42:26.477: Sent:
SIP/2.0 200 OK(<-FXS stop ringing)
30:5060
Date: Thu, 13 Mar 2003 06:42:26 gmt
Content-Length: 0
CSeq: 101 CANCEL
Silver
Re: SIP:FXS keep ringing when ATA186 Cancel call
I am not sure if you are hitting this bug CSCdv34778. It is worth checking though
This bug is onlly applicable to ua which is using CFNA with CSPS, and the ua send BYE instead of CANCEL when hang-up.
In my case, I am using SER as SIP proxy. The UA (ATA186) is sending CANCEL indeed and received by the the gateway (FXS)
SSng
222
