SIP incoming calls
I'm trying to use my voice gateway with a SIP provider but the VG is not able to receive inbound call. SIP Outbound calls work fine.
I have an AS5400 gateway with 12.3(11)T10 IOS image.
Below the sip-ua configuration:
sip-ua
authentication username USER password PASSW realm SIP-DOMAIN
calling-info pstn-to-sip from number set NUMBER
registrar dns:SIP-SERVER:5061 expires 3600
sip-server dns:SIP-SERVER:5061
then below the incoming dial-peer configuration:
dial-peer voice 5 pots
application session
destination-pattern NUMBER
port 1/2:D (the E1 voice port)
The CCSIP messages and events debugs are activated but I see only messages when trying to make outbound call.
Furthermore, the "sh sip-ua register status" shows nothing.
May someone help me?
Thanks in advance
Daniele
Re: SIP incoming calls
Hello, I have a cisco 2651 with ccme 3.3 and I want to route my external calls PSTN through my SIP provider.
parameters form provider are:
sip.provider.com
login and password port 5060
I have configured this in the sip-ua but I have problems.
All of the IP phones I have behond the router try to authenticate.
I only want 1 authentication from the router
Then i need to tell the internal extensions when they have to go to the PSTN via the SIP provider.
Please can you help me? Is there any example?
to avoid the registration of the ephone-dn on the sip provider try to put the no-reg option at the end of the number configuration line:
ephone-dn
number 123 no-reg
To send the call to the sip provider, try to create a dial-peer voice like this below:
dial-peer voice 1000 voip
session protocol sipv2
session target sip-server
destination-pattern XXXX
codec XXXX
To configure the sip-ua you might use the configuration that I wrote in my first message. You must change my "SIP-SERVER" with your "sip.provider.com:5060" and "SIP-DOMAIN" with "sip.provider.com", it should work.
I hope it helps you.
Daniele
Thank you very much.
But, I want to route all the calls different to internals ( in my case the internal extensions are 200,201,202...) to the SIP provider.
In Spain the fixed telephone numbers start by 9........ so In the dial-peer if I put destination-pattern 9........? It will redirect all numbers like that to the SIP provider?
I'd like to have a number like 0 or 9 to dial before a user want to do a external call like in the analog pbx. How can I do it?
thanks
am trying it but i'm very upset because I cannot get it.
I have configured the sip-ua but the only things that are trying to register in the SIP proxy are the IP phones.
I don't want that I want only register one time with the account I have configured in the authentication and then route calls with pattern 9........ to the sip provider
Please I need help
This is my configuration:
dial-peer voice 100 voip
codec g711ulaw
sip-ua
authentication username xxx password xxx
retry register 10
registrar ipv4:213.162.201.146 expires 60
sip-server ipv4:213.162.201.146
gatekeeper
shutdown
telephony-service
max-ephones 2
max-dn 2
ip source-address 192.168.3.1 port 2000
auto assign 1 to 2
user-locale ES
network-locale ES
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 4 gain -6
transfer-system full-consult
ephone-dn 1 dual-line
number 1 no-reg both
ephone-dn 2 dual-line
number 2 no-reg both
ephone 1
mac-address 0013.60C3.CE02
type 7902
button 1:1
ephone 2
mac-address 0012.431E.BF3E
type 7902
button 1:2
The logs I receive in the SIP proxy when I try to call to an external number like 964525351 are:
Admission Request BB00000149 : 1@192.168.2.200 => 964525351
$I=BB00000149 exec ifone..sp_gk_start_call '192.168.2.200','','1','964525351','BB00000149','1','Oct 07 2006 19:10:34','',1,'20','','','','DE813E7E-411611D6-80B2C5E4-BE2FDD31','213.162.201.146','2.5.0000@Cisco-SIPGateway/IOS-12.x'
go
BB00000149|STOP|404|>>APPL: AUTH FAILURE/UNKNOWN USER[CODE:2 ACCTID:-1]
Admission Reject BB00000149 : 1@192.168.2.200 => 964525351
I am very frustrated so your help will be great.
To access the SIP provider using an "external line" dial number you could try to modify the dial-peer 100 with
des-patt 0.......
When using the destination-pattern the first digit is stripped out so in your example the 9 is stripped out and only the rest of the digits are forwarded to the sip provider. In this case the 0 will be stripped out and the 9xxxx should be forwarded to the provider.
In the sip-ua configuration try to append at the username/password line the realm option, when I made my lab it was mandatory to let the authentication work.
About the ephone-dn I made my lab without using the CCME so I supposed that the no-reg option, used to avoid the registration on a h323 gatekeeper, works also for the sip.
384
