SIP or SCCP :- Both go with each other!!
I am little bit confused with IP telephony Implementation, when at the end user node, How using protocol SIP or SCCP differ; Do both SIP & SCCP goes with each other or END NODE can be configured with any either SIP or SCCP?
Specific feature wise what is the difference between end point configured for SCCP or SIP ??
Thanks in Advance and sorry if my Q is somewhat confusing !!
With best regards,
MS
Hall of Fame Super Silver
Re: SIP or SCCP :- Both go with each other!!
SIP actually does not provide all feature SCCP load provides, I read a link which I cannot find now that SCCP supports ~210 feature where Advanced SIP supports ~190. I listed the features not supported by SIP. I will try to dig it up and post it here.
Chris
Dear Chris,
Please let me know the features not supported by SIP as mentioned in your reply and also I am somewhat eager whether you are able to find that link which has the list of all features pertaining to SIP & SCCP.
With best regards,
Mani
Mani I completely forgot about it. There are 186 feature with CCM 5.0 SCCP and 176 with SIP.
The missing ten:
IPMA
Attendant Console
Video Telephony support (i.e. VT Advantage cannot associate with a phone running SIP firmware load)
Join Softkey
Direct Transfer Softkey
Local Tone-on-Hold
FAC/CMC
7914
MCID
Drop any Conf Participant
HTH, please rate all posts!
Chris
901
作成コンテンツを作成するには してください
