SIP to SIP IP to IP Gateway with CCM 4.1(3)
Hi all,
I'm trying to set up an IP to IP gateway that will enable me to place SIP to SIP calls from CCM 4.1(3) to a SIP long distance carrier. Has anyone done this? Willing to share configuration examples? I haven't really found a good SIP to SIP example on CCO. Really only been able to find H323 to H323. We do not use a SIP proxy. Is that a requirement for this to work? Thanks in advance.
  • Other Collaboration Voice and Video Subjects
Green
Re: SIP to SIP IP to IP Gateway with CCM 4.1(3)
Have a setup in the lab.
As soon as I arrived to the TAC and re-test it will send you the configs.
Thank you, I'd greatly appreciate that when you get a chance.
Come to find out, the LD carry only support g729r8. CM only supports g711 for SIP trunks (CM 4.1(3)). Can the ip to ip gateway be set up for transcoding as well?
Restrictions for Cisco Multiservice IP-to-IP Gateway Configuration:
Restrictions for SIP-to-SIP Call Signaling:
Transcoding is not supported.
SIP-to-H.323 Call-Signaling Features:
Codec transcoding (G.711-G.729) - supported
other:Transcoding is not supported on the Cisco 7200 and the Cisco 7301
copied from:cisco Multiservice IP-to-IP Gateway
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_guide_book09186a0080409b6d.html
I have not found a solution, but i'd be interested in what you find though.
126
