Community Member
SIP to SIP transcode
I have CME 3.4 running a full SIP environment. The 7940 phones register to my 2621XM via SIP on the LAN no problem. My problem starts when I want to use G729 on the SIP trunk over the WAN my VOIP provider. It appears that for some reason CME 3.4 won't transcode between G711 used on the LAN and G729 used on the WAN. According to the sip debug it appears the CME box send a cancel for no apparent reason after it gets a 183 Session in progress from the VOIP. Any help would be appreciated.
Community Member
Re: SIP to SIP transcode
Cisco's IP-to-IP Gateway can do transcoding between G.711ulaw/alaw and various flavors of G.729r8. It uses the Skinny Server when invoking the transcoding services. Transcoding could be invoked for any call whether it originates from CCM or a voice gateway.
Even though transcoding resources is done locally on ipipgw, the transcoding resources have to be registered to a SCCP server
(Either CCM or CME).
Here is a sample config
The only way presently for the IPIPGW to be able to handle transcoding is that it needs to communicate via SCCP to a SCCP server. You can do this on the gateway by configuring the following configuration. This will configure the necessary transcoding and SCCP server.
Here is a sample config:
sccp local
sccp ccm X.X.x.x identifier 1
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register MTP
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
maximum sessions 5
associate application SCCP
no shut
load 7960-7940 P00303020214
max-ephones 48
max-dn 48
ip source-address port 2000
sdspfarm units 1
sdspfarm transcode sessions 50
sdspfarm tag 1 MTP
create cnf-files
Community Member
Yeah I tried that but my 7940 isn't registering with my CME box via SCCP. Here is my config it might help to clarify what I am attempting to do.
ip dhcp pool ITS
option 150 ip
voice service voip
allow-connections sip to sip
rel1xx disable
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711alaw
voice register global
mode cme
source-address port 5060
max-dn 20
max-pool 10
load 7960-7940 P0S3-07-5-00
tftp-path flash:
file text
create profile sync 0003275550914141
voice register dn 1
number 2001
name Computer
preference 1
voice register pool 1
id mac xxxx.xxxx.xxxx
type 7940
number 1 dn 1
max registrations 24
voice-class codec 1
description Computer
interface FastEthernet0/0
ip address dhcp
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
ip address
duplex auto
speed auto
tftp-server P0S3-07-5-00.bin
tftp-server P0S3-07-5-00.loads
tftp-server P0S3-07-5-00.sb2
tftp-server P003-07-5-00.bin
tftp-server P003-07-5-00.sbn
dial-peer voice 1001 voip
destination-pattern 0..........
codec g729r8
session protocol sipv2
session target ipv4:*.*.*.*
session transport udp
clid restrict
authentication username ****** password *********
no remote-party-id
retry register 2
registrar ipv4:*.*.*.* expires 3600
Any further ideas would be great Thanks
