SIP
Does any one have information on configuring SIP gateways / phones and interaction with CM
Bronze
Re: SIP
I'm using a SIP trunk to connect CCM with a SIP proxy server (this eliminated the need for a gateway). The configuration of the SIP trunk is pretty straight forward.
Larry
Re: SIP
Larry ,
Can you please tell us the Barnd and Model of the SIP Proxy you are using. I have tried couple of SIP Proxy Servers and none of them contained any feature to configure a Trunk to other Gateway. They Only used to Exchange Inetrnal Calls between the Registereed Phone but can not getthem out to the PSTN.
Thanks for your Help.
M.Tag
150
