skills based routing and ResourceID in script
I'm scripting for skills based and wondering what I should use as the Resource ID: in the Select Resource step. Can someone help or send me a sample script with skills based routing? jwatkins@mstates.com
1 REPLY
Bronze
Re: skills based routing and ResourceID in script
Following is from the Cisco CRS Editor step reference Guide (3.1)
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_3_1/english/admn_app/step_ref/icd.htm#1025860
Select Resource Properties -> Property Description
Call Contact
Variable that stores the call to connect to a resource.
Resource ID
Variable that stores the Resource ID of the chosen agent.
Contact Service Queue
The CSQ from which to find a resource.
Connect
Option for the call to be connected to the specified Resource ID the instant the resource becomes available.
If Yes, the call is automatically connected to the available resource.
If No, the resource, if available, is selected but not yet connected.
Timeout
Length of time, in seconds, before the contact is retrieved back into the queue. (Default is 10 seconds.)
This value must be lower than the Call Forward No Answer timeout in Cisco CallManager.
Take a look at the following URL which gives developers to design IP ICD Script
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_3_0/english/admn_app/develop/index.htm
Refer the ICD.aef under C:\Program Files\wfavvid\ folder which comes as sample script in ICD bundle.
Hope this answers your question.
If there is more to your question, please elaborate
Venkat
113
