Slips errors in a Q.SIG connection
I have a connection between a PBX MD110 and a Cisco router C2851 running MGCP. I have Slips errors all the time, counter is increasing every few seconds. Calls are working well but I have a lot of errors. The MD110 is configured to supply the clock and this is the config in the router:
controller E1 0/0/0
clock source line primary
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
I configured the ‘clock source line primary’ in one of them but both QSiGs have the same Slip errors:
r2851ctp01#sh controllers e1
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20050620, FPGA: 16, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line Primary.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (422 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
48 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
48 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
E1 0/0/1 is up.
No alarms detected.
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (423 seconds elapsed):
Any idea? The config in the CCM side is almost the default…
Ruben
Re: Slips errors in a Q.SIG connection
hi ruben,
if the pbx is configured to provide clocking then if you set the e1 controller to " clock source line primary" then the behaviour is expected. please set the cntroller clock sourec "line" so the router derives clock source from the pbx. let me know if this help.
subhrojyoti
I have two Q.SIG connections: one is "clock source line primary" and the other "clock source line" and both of them have the slips errors!
Is this a normal behaviour? I have also tried with the two connections working as "clock source line" with the same result...
Any idea?
Ruben
177
