Community Member
slow call to PSTN
I have 3 partition - internal, external, international
3 CSS - guest(internal)
user(internal, external)
management(internal, international)
all phones are inside "internal" partition.
i put my routing list under "external"
Every time the management CSS user make a PSTN call, it take more than 10 second to connect. Can anyone advise why is it so, how do I improve the connection speed?
Thank you,
Re: slow call to PSTN
What is your internation route pattern. Is it 9.! or something like that. It should be 9.011!. I would need to know what route patterns you are using to know for sure. If you have 9.@ and 9.! it will wait 10 seconds to see if you are matching 9.!.
Thank you,
-Mckee
Community Member
Hi Mckee,
Thank you very much. I was using 9.!, i have changed it and it works fine now.
could you kindly point me to any document, I wish to know reason behind.
Thank you.
89
