Small Voice System
I am looking to deploy a 10 person voice solution. What is the smallest solution cisco provides?
Silver
Re: Small Voice System
Hi, the smallest solution is with CCM Express. See next url:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_data_sheet0900aecd8041c303.html
Hope helps you.
Thanks, just hard to justify that solution in a 10-person office, i.e. 1 internet router, 1 voice router, voice cards, POE switch, and bandwidth.
Erik,
You dont need two routers to do voice and internet. You can get a 2801 or 2811 ( i would prefer buyina a 11 instead of 01, but if budget is a concern 01 is fine). both routers have hwic slots which can populate voice and data cards. If you get the 2811, you can also get a nm16esw with POE that can be your 16 port switch with POE on all ports. The downside of using an 01 is that it doesnt have a Network module slot, hence you cannot use a nm16esw on a 2801.
Sankar.
Sounds good thanks for the info. Hard to make a decision. We like the idea of having two routers one for voice and other for data. Upgrading and maintenance seems easier when you have two devices.
Research the following URL to see if it is a solution that meets your needs:
http://www.linksysone.com/
114
