Community Member
SNMP for 6608 active calls
I have been trying to find a way to poll my 6500 for the total number of active calls via SNMP. I am looking to get this data into a graph made by MRTG.
From the CLI, I get the data via 'sh port voice active call'
Anyone have an idea?
Bronze
Re: SNMP for 6608 active calls
There are no separate MIB modules defined for the 6608 card. However, if you want to see the number of completed calls from Call Manager, you can use the performance monitor counters. To view the number of completed calls, start up performance counters, added a new counter, select "Cisco MGCP PRI Device" under Performance object. One of the counters is "CallsCompleted". This should show you what you're looking for. For more information, visit
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00800c4cd1.html#36551 .
Community Member
Thanks. Do you know of any way to see total calls for a PRI at a given point in time, or a way to start graphing the data?
140
