Softkeys not responsive
During a G729 call from a 7960 over a H323 gateway, the IP Phone softkeys are displayed, but are not responsive (hold, conf, etc). All other calls work fine. If the codec is changed to G711, it also works.
CallManager 4.1(3)
H323 Gateway - 3745 PRI
1 REPLY
Re: Softkeys not responsive
For conference,hold etc across H.323 gateway to pstn/fxs lines you would require to check MTP on the call manager.
Verify that
Venky
101
